You might try taper shank drills for the holes that require more accuracy.
Although that is a fairly deep hole your drilling.
How off line does it go ?
Stu
Hum .... interesting thought! It's a specialized operation, I wouldn't mind spending $$ on a bit specialized for that.... certainly takes the runout out of the equation. The trick would be finding one long enough to get at least half way through my material - I generally have to advance the drill bit in the chuck a bit with what I am doing now.
As far as how far off they go - it all depends on how meticulous I am with setup. generally not more than 3/16" over 10"/12' the real problems show up when the holes are out both vertically and horizontally.
those holes are nothing for 'deep' either ... drilling ramrod holes is the real tricky bit. I regularly have to make drill bit extensions 4' long and purpose made D reamers for the entry holes.... a giant pain!
