- Nov 24, 2014
- 3,414
@extropic here ya go!
Happy to add any more detail and you can find the exploded diagram on LMS here
- The pulley housing fits into the spindle housing with a clearance fit
- the pulley housing is fixed to the spindle housing with 4x m5 SHCS
- the clearance holes for the capscrews are nominal
I have no idea what you mean by a "clearance fit". Can you define it in terms of actual dimensions?
In the picture (reply #28) I see two small holes, opposite the flat on the circumference of the pulley support/bearing housing.
On the main body casting, faying surface, I think I see very slight (.03"?) protrusion of two C-pins (spring pins?) that are probably intended to precisely locate the pulley assembly. The pins are protruding so little as to be ineffective at precise indexing. Apparently, someone has tried to install the pulley assembly without paying proper attention to the pins and has driven them into a depth that renders them inadequate.
I suspect that the resulting misalignment is at the core of your noise problem.
I suggest you remove those and start over with fresh pins. If it were my machine, I would try substituting solid dowel pins and Loctite them them into the pully support housing, with about 2 x D protrusion for engagement into the main casting. The hole diameters would have to be compatible with that approach.
If the existing pins are C-type (hollow) as I suspect, I would try using an easy-out to turn and pull them out enough to get some Vise-Grips to finish the job.
