Thank you for posting on this
@RSC77 I actually saved your prior SW file somewhere & forgot I had it. Very useful! Hopefully this is a spot to ask you some clarifying questions?
I used it to develop metric gears by toggling units & defining: Module, Number of teeth & Pressure angle. Can you confirm that the other downstream equations are applicable to typical metric gears, or are there other adjustments I should be should be aware of?
Cut-Extrude2 is the shaft hole diameter which I was able to modify no problem. But what are the *DCGTBC (suppressed) features? The underlying sketch to first feature in tree shows the big orange circle.
Have you ever done a similar helper file for internal ring gears?
