I have been enjoying the various joys of working with metal for a few years but my machining expertise is pretty limited. I do, however enjoy the machining I have done so far which is mostly ornamental (machined, articulated LED lamps) and so far not needing high accuracy. I do think I want to start making small artistic mechanical movements that would require more precise machining, though. My machines are a Burke Millrite mill and a Rockwell 10" lathe (I also have a cnc'd chinese mini-mill that I use for making things like gears). The two mills are R8 collet size and the lathe takes 4C collets internally, which are difficult to find.
I have seen ER collets, I don't actually know where they fit it the scheme of things, and I wonder if they are something I could use on my equipment to advantage. Could anyone here tell me if I should look at those for my lathe, or look at a 5C chuck, or try to find a set of 4C collets, or forget the whole thing and use my 3 and 4 jaw chucks?
