- Dec 20, 2012
- 9,408
My lathe boring bars have different negative radial rake angles, that's why i am more confused about than i should be. ; )
I intended to comment on this and forgot. If you are using CCMT inserts in your lathe boring bars then the SCLCR bar and insert configuration has positive rake geometry. It is intended to be used with zero radial rake when positioned in your boring bar holder. Inducing negative rake with these bars defeats the purpose of the geometry.
Of course, they are your bars and you can use them as you choose but I just wanted to make sure you were aware that while inducing more positive radial rake is a common practice with solid boring bars, it is not a recommended practice with inserted bars. This is mainly because the cutting edge will then be out of position when you do this but also because you reduce the clearance angle under the insert and that leads to rubbing and consequently, chatter.
