- Mar 25, 2013
- 5,222
They are lying. The internal wiring of the DB9 connector only has 5 pins in use. It can't "read" the RS-422 signal but it would be compatible with the basic TTL. Their customer service rep also spoke to an engineer who indicated that the expected accuracy of the 1um scale was worse than .002" per inch.That is the TTL configuration. I talked to Ditron this week, they said the heads can read either TTL or RS-422-A (8 wires plus shield). The difference is TTL degrades in long cable runs, where the twisted pair bucks noise. By long runs, I'm talking upward of a hundred meters.
I'm curious what happens if you take a display that is expecting RS422 signal and give it 4 wire TTL from the read head? I assume you will see errors if it is expecting an absolute reference track?
