Die filer
that is one cute die filer!
my filer seems to run slow, next time i have it out i will take a video of it, and you can let me know if it is too fast. I haven't used it in a coons age, i should think of something for it, or leave it set up. Seems getting the bugger out, it weighs an easy 150 lbs, is the biggest deterrent to its use.
I never thought of grinding files down, makes sense now /forehead smack
I as going to say I wouldn't think one would want a fast moving machine for filing. I would prefer a slow and steady stroke/cycle so I could control the layout line. I've reshapened die sections that were split in the corners because die filers were not used. They look like nice machines. EDMs apparently replaced them in the die building shops.
Chuck,
I got the whole kit. I may have the plans but I haven't seen them for a couple of years.
One of the first things I noticed about the MLA was that it ran too fast, so I bought a HF router speed controller. That pretty much solved the problem, but a pulley change could be added to get a little more torque out of the motor too.
Randy
