- Jul 17, 2024
- 8
I recently got a lathe,to make a part for a belt grinder I want to build but can't remember what I needed the belt grinder for, probably to build something else I forgot about.
It doesn't have a motor yet but I decided to take it back to the nuts and bolts first and give everything a good clean with wd40, some plastic scourers, and nylon/brass brushes. I planned to give it a nice spray over the summer but the patina is growing on me. It was going great and despite looking like ****e to my beginner's eye the ways are flat across the full length and all the gears are in good shape though a little rusty. The spindle spun freely in each direction and none of the contact points seemed worn.
I couldn't get the chuck off and didn't have a motor to try the reverse trick. After ages of wd40 scrubbing and oil I managed to separate the rusted and bound chuck from it's face plate but the plate remains on the spindle. I couldn't work out how to remove the main spindle with all the back gears, pulleys, etc. After screwing the end cap thing off there was no play in the gear at the end of the threads. I remembered a lathe restoration video where they hammer the spindle through the gears. I tried this and quickly realised that I've crushed the first three threads on the end of the spindle so the end cap thing doesn't screw on now.
Is there a correct method to take this part apart and have I ruined the lathe?
