That's where I'm leaning. If it gets bad I can always weld something up. Now I just need to get to cutting and tapping the levelers so I can install them when the poly cures. I'm thinking to use long wood screws into the cross supports to attach to the bench. Maybe make them long enough to overshoot the supports as well and run bolts on the end through the bench with large washers on the backside as well. I'd have to make sure the bolt heads are away from the foot or otherwise can't interfere with the leveling bolts though. Might be more trouble than it's worth. I guess I could fire up the belt grinder and shorten the heads.
For the level adjustment bolts, how much length do I need? I wasn't planning on much, maybe 1/2" long.
