- Mar 2, 2013
- 895
To add a suggestion to Dave's point on cross bracing. Think construction adhesive when putting together the cabinet, all joints. Plywood to fit between the upper and lower section on the vertical back, glued and screwed. On each of the vertical 4x4 member sections, plywood, glued and screwed. Place a piece of plywood on the floor of each of the three sections and you now have 3 compartments to store fixtures, chucks, faceplate and anything else too big for smaller storage. Added benefit, that cabinet if built with care and braced with plywood will never move
