Derbyshire Magnus rehab
When I read the name of the thread, I thought that old Magnus from Derbyshire fell off the wagon again!
Great job.
Richard
Derbyshire Magnus rehab​
I went to a swapmeet this morning. I found 2 small 3 jaw chucks. I never see small chucks 2” or so. Anyhow scooped them up for $6 each. One is a craftsman with 1/2”-20 threads. The other is a made in India with a 12 mm thread.
The craftsman is a bit heavy I think. The India one is better suited. The craftsman runs smooth. As for the India it is unused and sticky. It will need a tear down and good cleaning. I will see if I can find the D style collet adapter for them. Worst case is I can modify the supplied MT2 on the India one. The pain will be making a Buttress threading tool for 10mm.
Cutting oil is my blood.
Interesting find on the India chuck. The jaws are reversible. Swap jaws 1&3 when flipping.
I started making a riser today. It is made from a 3” dia x 3” long piece of CRS.
To do the radial cut for the lathe bar to fit. I just took my 1-1/2” fly cutter and extended the cutter out to make a 1-3/4” dia.
I need to drill and tap 2 mounting holes on the bottom to mount to a board eventually.
Just painted it. I also picked up a piece of pine for the base. I will mess with that next week as I have next week off.
Double post fixed.
I got 3 hours in today. I was able to get pretty far on the tool rest. All I need to do on the flipper is drill and ream a hole for the tool rest holder. The pivot is reamed .126 through one end of the base and flipper. The other end is reamed .125.
Tomorrow I will do that and make the holder se toon for the tool rest and the tool rest.
Got another 1-1/2 in today. I have it all finished up except getting a thumb screw to secure the toolpost. I also need to make a knob to secure the entire holder down to the bed.
I made the adapter for my little India 3 jaw chuck. I will need to make a custom drawbar. As I could not cut the M10 buttress. I opted for 3/8-24.
Drawbar done except for final back length cut and some cleanup. I think I will pick up some aluminum and remake the handle in the future. To cut down on weight.
