mine came with a 5C holder for sharpening milling tools. it will sit at two different angles look like 5 degrees and maybe 15 degrees anyone have instructions on it use. it is also indexable for 360 degrees around the collet
Standard Enco (and many others) end sharpener. 24 indices, usually. Older design used an indent, newer ones are using a pin. Use: endmill in collet, set up one tooth, grind, index to next tooth, grind, etc. Setup:: you want the tooth to pass under the wheel as if you were cutting the wheel. Typically need several light cuts -don't go heavy, holder isn't that stable especially on the relief angle. Once you've done the ends all around, flip the holder to the big angle and grind the relief the same way. Note that this only grinds the ends of teeth. I've never seen one come with instructions, by the way.
