- Aug 22, 2017
- 157
Good morning,
First off I'm 100% new to machine tools. I play with old farm machinery and often run into NLA parts. I've wanted a lathe for a quite some time and had been keeping an eye open. I've also watched a pile of YouTube videos though the years, Mr. Pete and Keith Rucker have kept me occupied for hours.
Anyway, I picked up a Craftsman 101.07301. It's pretty complete, came with a new motor and drum switch. A 3 jaw Delta chuck and a 4 jaw chuck with no name that seems to be well loved. The gears are in great shape, the spindle has a little play but I'll replace the bushing/bearings. The carriage and compound are in really good shape, no nicks or anything, it does have a broken handle on the cross feed but from what I see that's a really common problem. It also came with a pile of tooling, some of it brand new/never ground and a bench that needs a new top (question about that later).
It's smaller then what I had planned on but the price was right and it was just a few minutes down the road. To me this is a learning tool more then anything, I need to start somewhere and this guy seems like it should fill the roll.
So now the questions:
It was really dirty when I picked it up. I get the impression that who ever had it before me just didn't want to clean it up and that's why it was sold. Not to rusty, just grime and grit.
I've cleaned up the ways pretty well, I soaked them in WD-40, and used a green scotch bright pad to work the grime off then I wiped everything down with lacquer thinner and reoiled. The carriage runs really smooth the first half of the bed but as you get to the tail stock is stiffens up. I know this is a sign of wear. I took my mics and went all over the darn thing. I'm finding almost no wear in the width of the ways but I do see a little less then a half a thousands wear in the height. I guess that's enough feel in that little hand wheel. The ways are also kind of beat up, quite a few nicks and such although they don't seem to catch the carriage. How much is this bed going to drive me crazy in the long run?
The bench it's on is decent other then the top. The PO made it out of bunch of 2x6s and they're all cupped and anything but flat. I have some 3/4 finish plywood at home. If I doubled that up would that make an adequate top?
Anything else I should be looking for? Like I said this will get me started. Sure is a cute little machine, if machines can be cute.
