Could use some guidance setting up my ATW Pacemaker
slodat
H-M Lifetime Diamond Member
Jan 20, 2021
296
As the subject says, I am setting up my new to me 1953 American Tool Works Pacemaker 14x30 lathe. I brought it home a few weeks ago. Finished installing the rotary phase converter and get it into it's current final resting place. I was able to level the lathe under one graduation on my Starrett 98's in both directions. I turned a hot rolled bar to see how things look. I got the best surface finish I felt I could out of it. The bar was about 1.1" when I started. The final pass was very light with a slow feedrate.
Results:
I’m thinking this is plenty good for a starting point on such an old machine. I welcome feedback. I have some nicer material I can turn for testing. The hot rolled was just what I picked up.
That's a good looking machine. Were you using carbide to make the cut? If so that would explain the finish. Carbide doesn't like light cuts, and the hot rolled will generally be a little more gummy. Might try an HSS tool and see how you do. Mike
Nice lathe.
Have you tried doing the same cuts while supporting the bar with a live center in the tail stock?
From your table, it looks like your getting some deflection of the bar while cutting.
Went from zero bubble across the ways at the tail stock to raising the front (operator side) one mark on the level. Chucked up a little thicker bar of mystery stainless.
1.1589 at the chuck end
1.1617 about 5 inches away at the tail stock end
That reduced it to 0.00056/inch taper. Thinking I’ll go one more graduation on the level.
Haven’t turned with the tail stock yet.
A Starrett #98 is nowhere near sensitive to level a lathe; probably the two collar method would be your go to method at this stage
I’m getting somewhere. Currently at:
1-1.13710
5-1.13885
Next up is getting the live center going.
Chucked up between centers, did some adjusting, including adding a spring pass after each cut. Looks like I’m in better shape than I was. Started at -0.0106 across 10.5”. Ended up 0.0004 across 10.5”.
This is with 2 graduations high in the front on the ‘98. While it may not be sensitive enough to do the entire leveling job, it did serve as a great indication of what I was changing with the leveling foot.
Final:
Getting a decent finish on the mystery stainless.
I welcome any feedback, advice, observations, etc. I’m new to this.
Only thing the last cut proved is that your head stock and tail stock are aligned.
How do I check for twist in the bed?
When I adjusted the leveling foot in front of bed on tailstock end, the tailstock end measurement changed accordingly.
Before you go too crazy, I would take a good look at your way's. Hard to tell from the pics, but looks like you have somewear, which can explain the measurements you have.
