- Aug 23, 2014
- 932
Royesses you have got all kinds of nice mods done to this mill. Nice job! Do the read heads ride in any sort of a slot or groove on the scale or do they just float?
So Sieg has a new powerfeed that you have as well. I don’t know how I haven’t been able to keep track of all of this new stuff. How do you like the power feed? Does it have enough power? Sorry for all of the questions but you’ve got a lot of neat mods done to your machine
Thank you for the kind comments. I am happy to answer any questions and share with the forum members.
The edges of the aluminum scale holder creates a small channel on top of the stainless steel cover, sort of a shallow u channel you can see on the photo of the scale with the end removed in post #27. The reader is able to fit inside this channel. The reader is set up to not touch the scale while the wipers do touch the scale. I place a thin business card between the reader head and scale while pressing the wiper bracket and reader into the scale and tighten the screws. Then remove the card and there is a small gap between the reader and scale. The gap is not very critical as I have held the reader an 1/8" away from the scale and it still worked. It has been very stable and repeatable. The reader should be centered on the scale face and the scale should travel as parallel as possible to the axis of the moving parts.
I replaced an old power feed with the new one. I really like the new feed and especially the clutch. It is faster than the old and has 2 limit plungers and a limit switch assembly to stop it before the table runs into the base. While the LMS/Sieg stuff is expensive it is well designed and works well. I really like the power feed. It seems to be more powerful than the old style. As with all this mini mill stuff you need fix minor things that seem to apply your machine. The grub screw on the power feed connector bushing was scraping the mill base when at the end of the righ travel. I raised the end plates up level with the table and readjusted the lead screw nut but I still needed to file the grub screw flush. I mounted the limit switch and plungers on the front of the table because the dro reader and scale were already mounted on the back side of the table. I had to make a new limit switch bracket and flip the two micro switches inside the case since they were wired for a backside table mounting. I have only good things to say about The Little Machine Shop and their service and support. I am very happy with the DRO and Power feed and would do it all over again.
Roy
