O
ome
Forum Guest
Register Today
When i Finally got my nose piece out of the spindle and I put the backplate on three times each time with good repeatability checking with the indicator. When I try to take the backplate off I realized it was quite stuck.
It is a buck chuck backplate, for a set tru 6" 3 jaw chuck.
There are no holes for a bar except the threade holes for the chuck body.
Should i assemble the chuck on the spindle and then use the chuck key w/out the spring and give a good wack with my dead blow hammer 50oz. /rubber coated?
any help is greatly appreciated.
Thanks,
Jon
Thanks,
Jon
