On this lathe, you might be better off with HSS tooling over indexed carbide. I'm sure many have done a lot of good work using carbide on these, but the machine is pretty light duty and slow speed. It was designed around HSS tooling and isn't built around taking the heavy cuts at higher speeds where carbide works best.
Yes, you'll have to sharpen HSS tooling, but the good thing is that you can do it with a standard bench grinder setup. No-can-do with carbide.
