- Sep 19, 2014
- 234
For you guys running water soluble oil/coolents be careful with the concentration you run. Often they are designed to work only within a percent range of mixture, example only 25-30%. That window keeps everything in solution. Outside of that it starts to separate and that causes problems. The separation can occur immediately, within minutes, or longer. Use what works for you but start with the directions.
From a once upon a time lubricants and violent chemist
