I'm in the market for a gage block set that I plan to use to calibrate my measuring tools and use as a calibrated shop reference. Therefore I'm only considering NIST traceable so I know my masters are verified against a universal standard. I'm looking at the SHARS grade AS-0 SKU: 303-5307C set that is NIST traceable with serial numbers. It's specs are 5µ (0.05-0.4"), 6µ (0.45-1"), 8µ (2"), 10µ (3"), 12µ (4").
At $415 I'm skeptical since the equivalent grade 0 Mitutoyo or Starrett are around $1600. However it does state they are measured according to ASME B89.1.9-2002 and each block is serialized and the deviation from the NIST traceable size is recorded.
Does anyone have any experience having a set like this independently qualified and verified their stated accuracy isn't bogus?
Am I wasting my time/money even considering something that is this cheap? Is there another brand I should be considering?
There is a Starrett Grade B 81 piece set for only 500, but the grade B specs aren't tight enough tolerance for what I want.
