Tom s, good find. I'm surprised that there's not more information on programing this pendant because it is very reasonably priced and very good quality.
The OEM codes may be the key as I'm sure it can be set up to your liking. Bob
Tom S, Let me know if you find anything as I also have the same problem. Bob
I started off with the xbox controller which works great and the keys can be easily reprogramed but I found the joy stick was too touchy for me as I crashed the lathe, more than once, and ruined some parts. I am presently using a wireless MPG controller which is by far more safer but a pain in using the rotary switch in changing the axis. I purchased the Mach3 CNC manual Controller for my mill but it has the same problems that tom s mentioned but works OK for the X, Y & Z axis. I think that I will still play with it see if I can get it to work as it was dirt cheap. BobTry the xbox controller.
Jay
