- Oct 7, 2020
- 2,356
- I finished my ELS install a week or two back. Here's a picture.
In adding the picture, I see that I still need to do a anchor for my cable to the controller/display (so not quite complete). But, it's in and it works. I ran for a bit with the original firmware from Clough42. But, I've already switched over to another branch of the code. The version I'm running now lets you
This version of the firmware is available here:
- show the angle of the spindle (in place of showing RPM).
- It allows entering "any" pitch for a thread, rather than a select few.
- And, it allows a "Thread to Shoulder" function that's pretty slick. Once you set the shoulder (stopping) position and the beginning position, it moves the carriage to cut up to the shoulder, then stops the carriage. At this point, you need to stop the spindle and then retract the cross slide. The firmware then moves the carriage back to the beginning location (even though the spindle isn't turning) and when there, you wet the cross slide (and or compound) for the next cut. Turn on the spindle and it cuts the next pass.
https://github.com/kwackers/electronic-leadscrew
I'll also note that the correct v-belt to go direct from the servo motor to the gearbox input shaft for my PM-1130v is a belt that SDP-SI doesn't carry. I started with their 575mm long belt and it is definitely too long. From Vbeltmart.com, I ordered a 570mm and a 565mm length. The 565mm is too short, but the 570mm is perfect.
The Branch code sounds pretty cool, but not being code savvy, I looked at the link and I'm not getting much out of it yet. I currently have my system on the work bench working with the Clough42 code. I'm slowly working on brackets for my lathe.
