I think I might have a slightly improved location for mounting the servo on the 1130v. Javaduke put his into place snugly, but I worry that having contact between the servo and other parts of the lathe might risk rubbing over the long term. And I'm concerned that the fit was so close that it might work on some lathes with some servos...but not in every case.
So I finally decided to open things up so I could see the entire area. I already had the lower motor cover plate off. I removed the upper motor cover plate. Just a few screws. I also removed the backsplash (which covers the back side of the motor). At this point, I could see this:
The obvious location for the servo is between the motor and the large lathe bed casting. But, it's just a tiny bit too narrow for an easy fit. It's hard to measure exactly, but I think the space is about 53-54mm wide while the servo is spec'ed at 56 wide. Javduke got his servo in place with some file work and it only fits when it's tilted a few degrees.
My though now is to move the motor away from the lathe bed casting. Just a little bit. The motor is mounted with four (4) M8 bolts. Those bolts are on the end of the black standoff cylinders and are clearly visible between the motor and the lathe bed casting. There's a few options:
1) A washer/spacer can be inserted between each standoff and the motor mounts. The two mounting bolts farthest from the camera are quite long (I see ~10mm of visible thread on the top one). The two bolts close to the camera have at least two threads visible, so my estimate is that a 2.5 mm spacer could be added. It might also be possible to use a thinner washer over the slot on the side toward the motor, buying perhaps another .5mm.
2) Any or all of the standoffs could be replaced with slightly longer versions for more distance than the washers would provide.
Bottom line is that it's possible to move the motor for more space and it's not that difficult to do so.
If the motor moves backwards, the v-belt from the motor to the spindle will be tighter. Mine is already annoyingly tight. However, the motor mount pieces are slotted. And at least on my lathe, the motor is currently down at the bottom of the slots. So it can be moved higher, as needed, to allow the belt distance to be adjusted.
