Re-installed the spindle using the pressing fixtures I made. This aluminum bushings keeps the pipe centered on the spindle so it pulls straight.
Using a precision class rear bearing, and made sure to align the bearing alignment Mark with the mark on the front bearing.
After installing and setting preload, measured the runout. At the front getting about 0.0002 and in the rear, about 0.00015. Pretty happy with these runouts.
I’m super happy with the fit of the bushings I made. It spins freely, and comes to a very nice slow stop, you can really feel the oil film in there providing a hydraulic drag.
Then started it up to test everything, and hell yes!!!, finally fixed the massive noise in the headstock. I’m going to put together a video of my diagnostic procedure, and how to go about deductive reasoning.
I still got to play around a bit with the belt tension. It seems kinda tight, however they’re flapping around a bit. Need to adjust the main variable speed drive also.
Couple important things to remember when re-assembling the spindle:
1: insert some wood blocks and make sure the spindle gets fully pressed into the bull gear. Only the wood blocks hold the bull gear in place.
2: Make sure none of the spindle ridges catch on the bearing dust covers, really each to catch and bind it up.
3: Go slow and easy, spindle should go in steady, if there's any abrupt change in resistance, stop, it's binding on something.
4: It's easy to catch the rear spacer that pushes the rear bearing in on the spindle ledge, that's why I made an aluminum bushing.
