How do i fixThis is a common problem. Fortunately, it also easily fixed. It is also why most experienced guys have a honking big 60 degree countersink somewhere in their tool chest. Trust me; you are not the first to experience this.
Thank you... But why have i never had to do it the hundreds before?Use a 60 degree countersink with an OD large enough to cut a taper on the inside of your part, then engage the live center and you're good to go. As for the damage already done, ignore it unless something sticks up above the surface. You can remove that with a diamond file or stone.
What if I cut a new surface on the chuck teeth?Have you checked to see if the headstock is aligned with the ways and that your tailstock is aligned with the headstock? New lathe, right? Did you check these things? I still think you need to countersink the work but it is possible that this could be made worse if something is out of alignment.
