Is this something new or what are the circumstances of it now appearing, is this a new lathe or old, do you also get chatter when turning or only threading? What technique are you using for threading? Up front it seems to be a rigidity issue or something is loose. Have you checked the gibs, tried to take passes with the gib locks on, have you checked the carriage gibs? Are you taking to deep a threading pass, is the piece held securely with the least amount of stick out. Also is your tool post slide angle set correctly?
Sometimes there can be surface finish issues related to single phase motors on lathes, but typically this would be seen in both turning and threading, and is a bit idiosyncratic as to it showing up on a particular lathe.
O.K. guys, and gals, I've tried every speed/feed combo, every carbide insert I have, every HSS tool I have, I've even put vibration isolation pads between the stand and the floor...nothing seems to work. Here's what I get... Please excuse my photography skills. You can not only SEE the...
www.hobby-machinist.com
