- Jun 12, 2014
- 5,166
I would check the gibs on the back and the front of the saddle that hold the saddle down to the bed, they can loosen and cause some movement in the carriage. As indicated the half-nut may be worn. Keep your compound and cutter holder as close to the work as possible, may be a rigidity issue. I do thread with only the cross slide, but you will tend to get a better finish with the compound if your lathe is not rigid. It varies. The DOC varies, but I usually start out at around 0.01" for the first few passes, then 0.005" x 2 passes, 0.003" and typically one spring pass at 0.001" or less. Do not take repeated passes with shallow cuts, as the cutter will chatter similar to what you have. Could also be the insert you are using, I pretty much use Carmex (Iscar) or Mitsubishi (VP15TF) slay down type , there is also some geometry differences for OD and ID inserts/holders. I would double check the height of the cutter tip so it is dead on as to height. Try some heavy cutting oil. I typically thread steel at around 120-150 RPM, Aluminum and softer materials at 250-300 RPM. I use an electronic proximity stop system, it allows threading speeds of up to 450 RPM and maintain a repeat stopping accuracy of around 0.0002". I also do not need to disengage the half-nut. When I threaded without the electronic stop, about 150 RPM was the limit of my reflexes (on a good day).
Carmex inserts,
Carmex inserts,
