Small snap rings, of the highest quality, are one time use items. Its a fact of life. The dimensions just don't work out well for the spring return of the metal.
This type of snap ring plier works very well. I normally use lang as they made this style for half a dozen other companies and are fairly inexpensive compared to the awesome knipex but still work quite well. There hasn't been a snap ring yet under 2" I have had trouble with the 12 piece set at work. I have the knipex at home as my current job doesn't allow us to use our own tools.
If you notice the pins are slightly bent inwards (set for internal snap rings). The tool converts from inside/outside by unscrewing the knob and flipping the halves over. The pins for an external snap ring position will lean outwards. This is the big difference between the replaceable tip tools that make it work so much better without slipping off. The replaceable tip models are to big physically as well for small rings making them awkward.
