Chambering short barrels in the headstock
Ken, what did you bore your ID to on yours?
I take it then that rigidity with something with this mass is not enough of a difference then to worry about. Thanks!
Exactly.
Steel actually has a shear modulus (rigidity) that is 3 times higher than aluminum, but in this application a lathe doesn't generate nearly the force needed to effect the aluminum fixture.
This hitch is rated for a 10,000 lb trailer.
Visualize the stresses involved with a truck towing a 10,000 trailer, hard stopping at a stoplight, then taking off again. His fixture is probably even more rigid than that hitch due to its much larger diameter.
2"
I mostly work on flat bottom Winchester and FN receivers. I needed a bigger hole that would have been necessary for Remington's.
I went down a rabbit hole of determining thread strength in aluminum and various steels because I was concerned about having cam pins or bolts in an aluminum fixture. I forget what the exact numbers were but it was many thousands of pounds (Think, guys testing threads with 20 ton presses)... at that point I quit worrying about it.
I meant to ask what you settled on for your set screws (or what ever the truing bolts are called on a jig like this)?
I am considering 3/8x24 as I feel a finer thread should aid in fine adjustments.
1/2-20 on the fixture.
I have 3/8-24 on my outboard spider and I'm sure that would be fine (and certainly less money in hardware)
I went with 5/16-24 on my receiver fixture. It was my intent to make its pitch similar to a 4-jaw. I'm content with it.
