Cast concrete lathe base
That sounds interesting but no where near what I would do. I just made the table top out of 6" channel with a bottom and several cross pieces welded in. I also made the lower shelf the same way then poured concrete. The lathe is actually bolted to the steel I welded across the top. This allows me to properly shim and true up the lathe.
I also covered the concrete with some table top epoxy to make it nicer looking.
The three—plate method is a modern technology that allows you to achieve the best results without measuring instruments.
