- Dec 21, 2018
- 2,190
David's discussion of mills is excellent. I've never used either type he discusses, I'm a hobbyist. I do think you should not translate the information about the Knuckle, tilt & nod, ram movements to a full sized knee mill. At least in my experience those connections are quite ridged. But my mill weighs about twice what the baby knee mill does.
When it comes to tramming the head, tilt is relatively easy but nod was a PIA for me. Both directions are driven be a gear system. Slack the locking bolts, use a wrench to rotate the worm screw and tighten, Simple, in theory but when you tighten the locking bolts things move. Especially the nod. It is very easy to move the ram & lock. Rotating the upper assembly so you can reach over the back edge of the table to work on the end of a long part that has been clamped to the side of the table is also easy but limited.
The back of the ram has mountings for accessories that I have no experience with. Just rotate the upper works and put that end over the table. Rotation is manual. At least in theory by using the rotation you could extend the maximum length of part you could surface. Same goes for moving the ram in/out. I don't know how much that would affect the over all accuracy.
The size of the table, used in the descriptions, 833, 8" X 33" or in my case 9 X 49 is not the usable machining area. The available X movement is considerably less. The knee & table add up to a lot of weight. so moving them up/down takes a lot of turns of the crank making a power Z very appealing. Ideally I suppose locking the knee when machining should be done. But any slack in the gibs will slightly change the angle of the knee when locked. I think that in practice the knee & table are so heavy that it would take pretty aggressive cuts to make them move. Take that into consideration before tramming.
Ceiling height. My mill has the Reeves variable speed belt drive. If you need to replace the belt it takes space above the motor! Rare but!
Moving a 2000+# machine. Once on the concrete using pipes won't work on my machine due to cutouts in the bottom. Rental machine skates & toe jacks are available. My machine has a lifting eye & I have access to a 5000# forklift & experience. The head can be rotated to get under garage door openings. The base is narrow and the machine is tall, so stability is lacking when moving it by the base. Be careful!
