- May 3, 2020
- 378
I am trying to combine the knee and quill z positions on my DRO. I need it to store a reliable z offset for tools in the DRO's library. The idea is to speed up the drudgery with a Haimer and DRO. (Probably would be better to buy a Haas but I'm 50k short and don't have a place to put a Mini Mill.)
TL;DR I'm installing an import DRO on a G0755. I'm considering combining A+ and B+ signals from two different read heads to sum the column and quill positions
In a little more detail: The DRO is a ToAuto brand Asian import but the 4-axis type. The manual is of the usual quality. There's some hints for adding axes in lathe mode but it uses the PCD-mode button so it seemed like a dead end.
I've looked at the boards in the read heads---they're surface mount with 2 pots, an LM339, and a AM26LS31C on the board. That last chip is a differential line driver but there's only 4 wires and the cable shield connected to the board. Two of those wires are labeled A+ and B+ on the silk screen.
I'm considering electrically joining the A and B quadrature signals from the column and quill. Probably with a multipole switch so I can use the scales separately or in combination. I know this sounds crazy but the output of the LM339 is a open collector NPN type circuit so it might work. The comparator output relies on the wire being pulled to 5 V all the time and pulls it to 0V when the comparator is triggered. So putting 2 LM339 outputs on one line might be OK.
Just wanted to do a sanity check before going any farther. Could it work? Is there another way to achieve the same end? Some other DRO I should have purchased?
