Can you guess the manufacturer of this depth micrometer?
I suggest a depth base that fits your dial caliper. More than accurate enough for most work.
Are the not too flimsy ?I thought about getting one that would fit my Mitutoyo caliper but wasn't sure how well they get screwed on.71-H3yd-9pL._SL1500_.jpg
I have a Mitutoyo Z readout fitted to my Bridgeport mill. I use it all the time for the reason it was designed. And then I found out I could mount a 1/8” diameter rod in the spindle and also use the Z readout as a sort of digital depth mike. In most causes it works as good or even better than a stand-alone depth mike…Dave
So I looked at my Lufkin, it has 3 rods, 1 installed and 2 as in the pic. Those wrenches to not belong to the depth mic. They belong to the Lufkin bore gauge, which I have too. The wrench is much different for the depth mic. I think the 3rd rod is loaded in the mic. It appears to have a certificate attached in yellow.
The Etalon 6" calipers usually come with the depth base attachment as part of a package. My Etalon dial caliper came with one.
They attach securely and work well for what they are. To calibrate depth mic rods beyond 3" requires large gage blocks or very accurate
2-4-6 blocks. A lot of trouble and expense for .001" accuracy. There are no tenth reading depth micrometers.
