Hi. I needed to make some custom nuts and bolts, so I used an old 5/8-11 die from a set, and a vintage 5/8-11 tap. The nut and bolt fit together, but it was a low quality fit. The more threads meshing, the tighter the fit got. Then, I noticed the letters "USS" on the tap. It's an old one. A web search said they were slightly different from UNC, but still interchangeable. The nut would go on the bolt, but the fit was too tight. Could the difference cause this, or is it more likely just a matter of a worn die. I've always taken thread fit for commercial taps and dies for granted up to now.
