Finished up cutting the stand down, mounted the lathe and rolled it into its future permanent spot:
Looks pretty good!
I've still got some details to work out like making sure its squared up, a removable chip tray, sealing up the seam between the two tops, etc.
There's a piece of 1/4" plate under the headstock+motor as well as a piece under the tailstock mount. Plan is to tie them together with some square tube or heavy angle. Haven't decided yet. Not sense squaring the lathe away until that welding is done.
I still have one steel door to cut down and mount on the back, but that is a project for another day. Low priority on that one.
I'm considering something to fit in the space behind the lathe:
Not quite sure what though. I was thinking a flat piece on a stand to hold my chuck keys and maybe collets, maybe the dead and live centers but I just can't decide.
I've got so much ctorage space inside its actually hard to figure out where to store things!
I chucked up an old scrap bolt I had lying around and made my first chips. The lh tool holder had an old HSS cutter in it and it did a pretty messy job. It also seemed like the carriage moved around a bit as I entered the work piece. Carriage seems tight, might have just been my eyes. Seems like lots of backlash in all the carriage feeds, might need a few new things like half nuts. The dials on the cross slide don't turn with the handle, I think its just the set screw. The thread dial doesn't turn at all. It looks like it should be engaged in the lead screw, but its nowhere near close to it. Have to investigate that. Feed speed seems kind of quick, it seemed to groove more than anything else. In all fairness, i didnt even look at what gears are in the train. I just wanted to see it run for the first time since i bought it.
For sure the whole machine is going to need a good going through.
That's part of the fun for me though.
I just hope it doesn't need a lot of parts to bring it back up to snuff.
