I have made several projects with the "spiral index centers", as B&S calls them, spiral gears, fluted cutting tools, dividing metal rules, and a cam.
The latest project was to cut a pair of spiral gears with axes at 90 degrees, with a 2:1 ratio, these were timing gears for a "Frisco Standard" 4 HP marine engine; the interesting part is that both blanks were the same diameter, I had the original gears, which were very badly pitted, I started with the crankshaft gear, which had a rather long spiral, easy to set up as the spiral angle was about 22-1/2 degrees, so swinging the table to that angle was no problem; then came the camshaft gear, where the spiral angle was the complement of that angle, exceeding the limit of table swing, so, I had to use the universal spindle attachment and swing it in a horizontal plane to the necessary spiral angle with the table at zero.
Some may wonder how a pair of gears of 2:! ratio could be the same size OD --- so did I! the lead of the first spiral turned out to be four times that of the second gear, and when cut with the proper cutter for that number of teeth, the tooth space is wider than on a longer spiral or for that matter, a spur gear, so that the two mesh properly when assembled. For that reason, it is possible to replace spur gears with spiral gears, usually one diametral pitch coarser (I think) than the original pitch, by computing the proper spiral angle so that the gears apparent pitch diameters are the same as the original spur gears.
