- May 3, 2020
- 338
I believe this is standard practice in commercial shopsCarbide is brittle, a punch might break it up.
Battery acid doped with Alum will remove the hardest steel from aluminum, but I doubt it would work on carbide.I know i saw a thread on this some where here. Now I can't find it, I thing they used some kind of acid to desolve out? Tried useing a carbide end mill amazon carbide to mill it out, and it just heated up and smoked I had the mill PM 935tv all the way max rpms. The drill is just cheap carbide as well. Any help would be appreciated as always.
CH
What I was wondering...How big is the drill in question and how deep down in the hole?
2.5mm I was trying drill out a 3mm broken off screw in the hole. That dang screw was harder than all git out too. That didn't help any. It is supposed to be 3mm-.5 x12 metric screw. I punched the screw as close to center as could. Thes tarted drilling with s carbide left twist an it went about I guess 5m in then it snaped it broke off. Down in the bottom. I know I should have left alone until I could get help but you know, just had to try.Battery acid doped with Alum will remove the hardest steel from aluminum, but I doubt it would work on carbide.
Going at a carbide drill with a carbide endmill may have sealed your fate here.
How much of the drill is stuck?
Looked in the phone book but the the nearest edm shop is in Denver about 75 miles of the worst traffic in the world. Maybe 2hr each way maybe longer. We are now little Comnuirodo! So many Comufoniaist out here now.An edm will blast right through that carbide drill.
CH
Is the broken screw flush with the surface? you might be able to braze a bit of key stock to the end and turn the screw out. Otherwise the EDM sounds like your best bet.2.5mm I was trying drill out a 3mm broken off screw in the hole. That dang screw was harder than all git out too. That didn't help any. It is supposed to be 3mm-.5 x12 metric screw. I punched the screw as close to center as could. Thes tarted drilling with s carbide left twist an it went about I guess 5m in then it snaped it broke off. Down in the bottom. I know I should have left alone until I could get help but you know, just had to try.
CH
See post #14You have left out some vital info. [if I missed it in scanning the entire thread twice, I apologize]
How much of the drill is in the workpiece? 1/2" long? 2" long?
What is the diameter of the drill?
... for the win -- how deep is the top of the carbide drill part?
Do you have the option of using an annular cutter to remove stock around the drill (ID must be close to the OD of the broken carbide drill)?
-- There isn't a one-size fits-all solution unless you have a portable sinker EDM, which was mentioned above.
Is this part so valuable you cannot scrap it?
There many more.
