Boring A Long Tube
Guys
I have one last boring operation to perform on an aluminum tube for my Crayford style focuser. Photo of my 99% finished Crayford focuser (minus anodizing) is below and the tube in question is at the top. It is about 4" long and has a rough ID of 2". View attachment 114000 My lathe is Grizzly G4000 and the longest boring bar can stick into the aluminum tube to a depth of about 2.75". The real boring operation to be done is very little. I just need to enlarge the bore to accept a 2" astronomical eyepiece or a 2" adapter. Since my longest boring bar is not long enough I guess after completing the boring operation from one end of the tube I will have to turn the tube around and mount it the other way to continue the operation from the other end. I want to achieve uniform bore without a perceptible step over the entire length on the bore.
I am not sure if I will be able achieve it to truly centered on the chuck when I turn it around to continue boring from the other end. Also, how will I know that I have arrived at the same diameter as I got when I did the boring from the other end? I am lost. Hence this post. I am seeking your advice.
My equipment: G4000 9x19 lathe - unmodified (i.e., I use the original 4-way tool post)
Chuck#1: Original 4" 3-jaw with internal and external jaws
Chuck#2: 6" 4-jaw independent jaw chuck (LMS) and a set of soft covers on top of jaws to prevent denting of aluminum material
Boring bar set: 1/2" shank carbide tipped set of from LMS with holder to suit.
Thank you guys,
Prasad
AB3EH
Wynnewood PA
That is nice looking work. Do you have any drawings of the project
