- Nov 16, 2012
- 5,596
I once had a surface grinder that had threaded holes in the cast iron base but the threads were butchered-up beyond repair. In pinch, I drilled-out the holes and put 5/8 threaded rod thru with adjusting nuts at the top and bottom. Furthermore, I welded some 3/8 plates to the threaded rod then, set it down on top of 4 rubber hockey pucks; one under each leg. It worked perfectly and cost almost nothing.
Ray C.
Ray C.
