I guess I'll be the contrarian in the group! I've not been impressed with the power transmission capabilities of the link type belts. I've tried the Fenner and also the no-name imports. Yes, they can improve smoothness, but over what? To me, there is nothing better than a high quality notched v-belt from a respected manufacturer like Gates, Dayco, or Browning. I pretty much use Browning since I have two PT dealers nearby who stock a good supply. They are available in classical (ABC), and light duty (4L). The classical are identified as AX-36 as an example. A simple comparison of drive tables for a given set of sheave sizes will show the tremendous improvement in HP for the notched belts vs. plain. The notches allow the belt to conform more easily to the sheave, improving smoothness of the drive. Raw edge construction grips the sheave well.
As a side note, I've found the drive engineering totally lacking on a lot of commercial equipment. Sheaves too small, grossly undersized belt drives for the claimed HP. Rant off--kind of a pet peeve of mine!
Regards
Bob
