Thanks for the input everyone. The machine was purchases in the late '80 for a Raytheon auction and I assumed it used for something special.
Currently I use my Maximat Compact (see pic below) for light duty milling/learning to mill. Do you think this Bridgeport would be capable of heavier duty milling? Heavier than then the Maximat that is.
Hate to be the "contrarian" :whiteflag: but
someone should say it. And you asked: "what would I do?"....
If you have a maximat I'd expect the table and post for the M head to UNDERPERFORM what you already have!
There is no way you're going to transfer the ~1? HP of that head into that tiny table -- too little clamping; too little
stiffness in the 2-1/2"? post; and you take a chance of flipping that
tiny split clamp table right around the post every time
you hit some hard spot in the material -- or mis-gauge your initial depth of cut guess!
It makes a nice quill for making counterbores/sinks.
That's about it. Not enough post height to hold a standard drill and chuck.
My Van Norman #12 frequently drives me a little crazy hunting for Z room and it has almost 7 inches between spindle and table!
A 4" drill and ~2" chuck and adapter chew that up pretty quickly.
What good is a drill press where you have to dismount the part to get the drill out? Think about it!
So; trade it for a
real drill press -- like a Delta 14" or 17" floor model -- making a nice combo with your Maximat. And
"google
is your friend". A brief image search of 'cincinatti mill and bridgeport head' yields a fair amount of eye candy and info.
No need to copy those images here! And the linked pages hold lots of beginner info and places to start your search.
You will quickly come to the conclusion that
there is a reason these heads are mounted to a beefy table; reasonably spaced
real "ways" and a stout column! This setup is of
extremely limited use without these features. This is why people mash them
up with old universal mills -- cheap
real iron tables of stout design premise to match the HP of the head.
You wouldn't enjoy a 350hp V-8 stuffed into an MG Midget. Same deal here. The basis is too flimsy to make the package
enjoyable. And if you're not doing this for the pure enjoyment .... nuff said.
I have two of that same drill press base and they cannot handle
any side load to speak of. They're
extremely useful with
the 1/4hp belt drive motor and ~2" stroke quill that came with. Don't waste your money on
an X-Y table -- only to discover its a dangerous idea as the part comes flying off
with the table. Or the entire table cracks
off the post at the clamp!
--frankb
