- Jan 16, 2015
- 26
With single phase the drum switch simply swaps the Hot and Neutral back and forth. Try manually swaping the hot and neutral on the drum switch and turn switch forward. If the motor runs reverse then the motor is wired right then yes the drum switch is incorrectly wired. If nothing happens or the breaker trips then its the motor end we need to look at.
