- May 16, 2016
- 1,704
I would discharge the battery and then charge it with some kind of limiting resistor in series with the charge leads. A car
tail light works well for this( #1157 comes to mind). That way it can reverse it's polarity without much danger. I often use
this method on smaller batteries that would be cooked with a regular car charger.
Thanks I have two small chargers the 1A one mentioned and another that I can set at two Amps, I think either of them will suffice I'll probably use the 1A one, but yes it won't charge a completely flat battery so I'll interrupt the discharge before it's completely flat.
