- Aug 29, 2016
- 867
I grew up working on positive ground British iron. Yes, you can reverse charge a battery. Not well, but it will show -12 on a meter. Drain the current charge (light or some such load), then charge it normally.
OK, that is a new one. Is it possible that you had the charger connected backwards? I really don't understand how a battery can switch polarity. Hopefully someone here can explain how this is possible.
This is just a guess, but I would think that the battery is done.
Hi guys, I recently set up a LED lamp above my lathe, it required 12v. I had a spare 12v gel cell battery looking for a purpose, so I hooked it up. Nice bright light with it's own on/off switch. I added a small plug pack charger, 1 amp, and capable of floating when fully charged. I also intend to run a few more low power items off this setup.
After a couple of hours running I switched it off and retired for the night. The next day I went to switch it on and the light didn't work, put multimeter on battery = 12.5v ? assuming the new light fitting was faulty I took it down and pulled it apart, Another similar battery was on the workbench so I touched the light wires to it and presto it worked. Went back to the original battery, wouldn't work? checked battery again 12.5v? take a second look at meter -12.5v switched the meter leads around and got+12.5v. hooked up the led light wrong way around, yes it worked. ????
The two batteries are identical 12v gel cells about 2 years old, now one of them suddenly decides to switch polarity, overnight with every thing turned off.
Any clues gentlemen, and ladies? Can I get the polarity to switch back, or can it be used like this.????
Since it worked for a while, I suspect you started with a hot battery, and the puny 1A charger has a current limiting circuit in it. This would be why it didn't catch fire the first time. I wouldn't temp the luck gods any more. Don't use the charger to drain it down, use a standard inductive load that doesn't care about polarity.
Thanks Pierre, that is more or less what I intend to do. surprised that it is somewhat common.Just put a light across to discharge it and then when flat charge normally. This happens more often than one would think. The only thing that one can run into is an automatic charger may not start if the battery is completely flat. Either use a manual charger or hook a charged battery in parallel to give the sensor a voltage to start, once there is a small charge you can remove the charged battery or leave them both hooked up until both are fully charged.
Pierre
