- Apr 30, 2012
- 2,401
setting the best step rate for the normal use of the machine depends on what it is doing. you can set the machine to have really fast rapids and it will have bad vibration at slower cutting speeds. you can set higher microsteps to smooth out slow feeds but the top speed of the motor is much lower. that is why if you can you want big motors to be able to have smooth low speeds and enough torque left to still move at high speed during rapids. i included 2 videos of my machine as i was still trying to work out the proper microstep i needed for the way i will use my machine. the first on is at a half step (400 pulses per revolution)note the vibration but at this setting the mill will move at 200 inches per minute rapids. the second video is set at 5000 pulses per revolution and note how smooth it sounds cutting at feed rate of 9. the mill will now only rapid at 100 ipm any faster and the motor does not have the power it needs and falters missing steps. you can actualy hear your motor missing steps anything that is not a steady humm or buzz is a missed step and recovery.so if it dont sound right it isnt right.
first run
[video=youtube;3PXo4sqKEyY]http://www.youtube.com/watch?v=3PXo4sqKEyY&feature=plcp[/video]
200 ipm listen to the motors
[video=youtube;1jWF1JW1JnE]http://www.youtube.com/watch?v=1jWF1JW1JnE&feature=plcp[/video]
my final setting for smooth motion at feed rates
[video=youtube;DcsYpc4I7mY]http://www.youtube.com/watch?v=DcsYpc4I7mY&feature=plcp[/video]
steve
first run
steve
