- Sep 20, 2012
- 560
I just started on this forum and I do not want to rub anyone wrong but I worked in a Machine shop for 25Yrs all of are machines are manual no CNC. I built my first metal turning lathe but came across an 10 inch Atlas for a song and could not turn it down. There are some design flaws but nothing that any of us could not repair or design better. I just recently rebuilt the cross feed and updated it with bearings, a direct read dial and a cross feed nut that is twice as long as the stock one with wear adjustments. I also installed a 2 1/2 horse variable speed treadmill motor to it and other small modifications. I have used the counterparts of this lathe and found no huge differance, I dont tend to blame a machine because I could not make do what I wanted instead I try and figure out how to make it work better and that is part of the fun of it.
As for the the Zamack (pot metal) parts if and when they fail you can buy almost exact replacement change gears from Browning and yes you can weld the atlas pot metal with Aladin 3 in 1 rod with a Tig welder I have welded mountains of this stuff and it welds quit well.. I for one see no problem with the Atlas Lathe it may in its day been inexpensive but is far from being a cheap lathe.. Ray
Hi Ray, I'm sure there will be a lot of interest in your crossfeed modifications, would you like to start a new thread detailing what you have done with pictures? I only ask because I have to make a new nut soon, and any help with this would be great.
Bernard
