- Dec 1, 2012
- 28
3 N 1 is a great Idea, Im going to look for some today.
I'm guessing that motor oil doesn't evaporate very quickly, especially in such an enclosed environment, and that at some point there will be enough oil trapped in the system for the bearings to self-lubricate as the bottom of the bearings roll through the pool of oil (assuming no leakage past the shields). Does that seem like a reasonable conclusion? If so, then how do you know when you have enough? I'm guessing you'd know for sure you have enough when oil starts flowing over the ID of the shield. )
Allen
Bernie,
Sorry. I was referring to your statement that most lathes with felts in the spindle bearing oil cups seem to have sleeve bearings. The confusion stems from two sources.
(1) Very few of the machines on this list were bought new by the current owners. So the current owner has no way of knowing what was actually on the machine when it originally left the factory.
(2) The Atlas and Craftsman parts list prior to around 1960 do not list a lot of small or miscellaneous parts like set screws and felts. The later manuals do. So the fact that your parts manual may not show a felt in the spindle oil cups or a set screw in the bull gear or most collars does not mean that they aren't or weren't originally there. Unfortunately, Sears does not seem to have done a corrected parts manual (after about 1960) for the sleeve bearing 6" machines so I can't say whether they had felts in the spindle bearing oil cups or not. As far as bearing oiling goes, I would say that they really aren't needed with the sleeve bearings. However, they can serve a secondary purpose of keeping swarf from getting down into the cup neck.
The spindle oiler felts are one piece and only in the cup body. They do not extend down through the neck and do not touch the bearings, regardless of bearing type. Also, the small oil cups on the QCGB, carriage and underdrive countershaft do not have felts.
Robert D.
