KD,
The Atlas Quick Change Gear Box first appeared in late 1947, at about the same time that Atlas discontinued the 36" and 48" beds (so there are no QC36 or QC48's). Initially, Atlas started the serial numbers on the QC's at 1 or maybe 100 or 200. At some later point, they were merged into the S/N block being used by the change gear 10F's. Best current guess is that this happened around 1951 and may have coincided with the QCGB change from No. 1500 (which yours is) to No. 6800. This happened sometime before S/N 082925. So far, yours is the highest 4-digit serial number reported. And the only one with an "L" suffix. So for at least the time being, we'll say that your machine was made in 1950.
Although they are not real common, you should be able to eventually find a replacement belt cover and motor mount on eBay. All parts on your machine except for the QCGB and bandjo (change gear bracket) are the same as on the change gear 10F. Of which at least 80.000 were built.
Your machine has the not real common but not rare either factory floor stand. And it has the uncommon factory drip pan.
There is an Atlas machine database in Downloads. As soon as you can see the Downloads tab on the upper tool bar, go to Downloads, click where it says to click here 1st, and 2nd. Click on Atlas/Craftsman/AA, and scroll down and click on A/C Database. I didn't realize that they had gotten that far behind (I'll update them shortly) but there are three files with .TXT extensions. They are actually .MDX, .DBF and .CSV files. Adding the .TXT on the end was a trick to allow them to be uploaded. After downloading, change the file name by deleting the .TXT from the end of the file name. The database includes all types of Atlas machines, including those sold by Sears. Plus the 6" lathes sold by Sears but made by AA.
Also in Downloads you will find a lot of manuals and Atlas Technical Bulletins and etc.
