Pat,
Even though it is a 6x18, it is never correct to refer to the 101.07301 as a 618. 618 is an Atlas model number - only. In the 1930's Atlas sometimes used the lathe size figures to generate their lathe model number (they also made a 918 for example). The two 6" lathes sold under the Atlas badge in the early years were 618 (which is a 6x18) and 612 (which is a 6x12).
Rodney,
Atlas started making the 6" (both 612 and 618) in 1937. The 618 remained in production until 1972, when it was replaced by the 3950. The last catalog that the 612 appears in is the 1941 General Catalog. They apparently did not print a catalog in 1942. And the 612 is missing from L43 (the 1943 catalog on lathes) and all subsequent catalogs. So I have tentatively set the production life of the 612 as 1937 to 1942.
In the Atlas database, we have 54 618's listed, of which we have serial numbers for 45. We have absolutely zero 612's. Until now. The bed lengths on the 10" and 12" don't appear to have affected serial number assignments (next machine off the line got the next serial number). So probably the length of the 6" didn't either. Unfortunately, the spindle bearings from the 6" don't ever appear to have been dated as the 9", 10" and 12" were up through about 1957. So dating the 6" is an iffy proposition. However, 618 serial number 004073 in the database has a note from the current owner saying that his Grandfather purchased it new from Atlas in 1941. So probably your 612 was made in 1937.
On your mill, according to the serial number, it is actually an MFA. Check and confirm that the spindle pulley has three steps instead of four. As far as I can tell from the catalogs, Atlas didn't start calling the 12-speed machines M1A, MFA and MHA until they came out with the 8-speed M1B, MFB and MHB. Based on the catalogs, I have the production years for the MFA as 1942 to 1944. The first MFA serial number is supposedly 001345 so yours was probably made in 1942.
