Interesting thing I noticed earlier today with the lathe. I've been going through the gears in the quick change GB (while rotating the spindle by hand), but cannot get the left lever into the "E" detent. I can get it close, but not quite all the way. I've also noticed that with some settings on the QCGB, it becomes difficult enough to rotate the spindle that it causes the belt to slip. Now, I haven't actually tried it under power, wanted to make sure all the bugs were worked out first.
I assume I will probably need to pull the QCGB and check it, anything else I should be looking at?
eta: Also, how do I correctly "size" the belt running from the electric motor to the main pulley? I know the length isn't too much of an issue, but how thick should it be and should I use a cog/notch style or standard V pulley?
