Next up for cleaning was this mess.
Start by removing the set screws in all the pulleys/collars. There's a set screw in each pulley and one in a collar.
This one from the stepped pulley is longer than the others.
One in the braking pulley.
The large pulley on the opposite side mates up with the motor.
And there's one in the collar on the inboard side of the large single pulley.
Next I removed the brake/clutch lever. There's two small pins that capture it on the cast iron bracket.
They tap out easily.
Now the lever with its shaft can slide out to the right in the below picture.
Now the pulleys can begin coming off. These were very stubborn in my case. A 3 jaw puller would have been great and I've been meaning to get one for years. I actually lightly damaged a small woodruff key and some of the pulley IDs by trying to beat them apart. There's a small key that holds the large single pulley but the collar does not have a keyway cut into it so the key must be removed before the collar can come off.
Now the shaft can be removed with the step pulley still on it. It was easier to work on this way.
The roller bearings can be easily slid out of the cast iron bracket and the casting is bare at this point.
Now the brake pulley can be slid off.
This is the side that goes up against the step pulley.
And this side goes against the casting and the roller bearings. Note the completely flattened out felt seal. Not much sealing here anymore.
Here's the collar that was inboard of the large single pulley.
And its old felt seal.
Finally I managed to tap out the shaft. All the parts are now disassembled. Time for more cleaning!
